I want to use mailbox for memory sharing purpose at transmitter and receiver sides.
Suppose I have message buffers mapped with a memory with specific address. By using these message buffers how I can configure control and status word of a mailbox.
In reply to MkRishi:
Why you don’t want to use TLM’s to transfer data between components?
In reply to Naven8:
Thank you for writing.
I am not using TLM’s because TLM’s support one directional ports.
I have a scenario for multi master in which every node will share the same address in the memory. All registers are mapped with same memory and configuration same for all nodes
I think you may be confusing TLM with uvm_tlm_fifo. The UVM’s TLM ports/exports can certainly be used to implement bi-directional communication. A uvm_tlm_fifo is just an example of a uvm_component with an internal mailbox that exports two TLM ports, a unidirectional put and get port. You can implement your own component with bidirectional exports.
But we would need to know a lot more details about your issue to help with an answer. What kind of control and status of the mailbox does your situation require?
