How to use layering sequence in sdram model
enum int { ACT=0, WRITE=1, READ=2, PRE=3, REF=4} val;
class sdram_sequence_item extends uvm_sequence_item;
   val cmd;
    reg [7:0]   data_in;
    reg [7:0]   col_addr;
    reg [1:0]   row_addr;
    reg [1:0]   bank_sel;
    reg         act_cmd;
    reg         pre_cmd;
    reg         ref_cmd;
    reg         read_cmd;
    reg         write_cmd;
    wire        dqs_in;     // To DUT active high
    wire        dqs_out;    // From DUT
    reg         data_mask;
    reg  [7:0]  data_out;
    reg         write_active;
    wire        dqs_inout;
   // int delay_pre;
   // int delay_p1;
  `uvm_object_utils(sdram_sequence_item)
  function new(string name = "");
    super.new(name);
				/////Act/////
class sdram_activate_cmd extends sdram_sequence_item;
  val cmd;
    rand bit [1:0] row_addr;
    rand bit [1:0] bank_sel;
   int delay_pre;
  int delay_p1;
  `uvm_object_utils(sdram_activat_cmd)
    cmd=ACT;
    delay_pre=0;
    delay_p1=4;
    super.new(name);
         		////write////
class sdram_write_cmd extends sdram_sequence_item;
  val cmd;
  int delay_pre;
  int delay_p1;
  `uvm_object_utils(sdram_write_cmd)
  rand [1:0] bank_sel;
  rand bit [7:0]  col_addr;
  rand bit [31:0] data_in;
  function new();
    super.new(name);
    cmd=WRITE;
    delay_pre=0;
    delay_p1=4;
			//////READ//////
class sdram_read_cmd extends sdram_sequence_item;
  val cmd;
  int delay_pre;
  int delay_p1;
  `uvm_object_utils(sdram_read_cmd)
  bit [31:0] data_out;
  function new();
    super.new(name);
    cmd=READ;
    delay_pre=0;
    delay_p1=4;
				/////Pre//////
class sdram_pre_cmd extends sdram_sequence_item;
  val cmd;
  int delay_pre;
  int delay_p1;
  `uvm_object_utils(sdram_pre_cmd)
  function new();
    super.new(name);
    cmd=PRE;
    delay_pre=0;
    delay_p1=10;
				/////REF/////
class sdram_ref_cmd extends sdram_sequence_item;
  val cmd;
  int delay_pre;
  int delay_p1;
  `uvm_object_utils(sdram_ref_cmd)
  function new();
    super.new(name);
    cmd=REF;
    delay_pre=0;
    delay_p1=64;
class act_seq extends uvm_sequence#(sdram_activate_cmd);
  `uvm_object_utils(act_seq)
   function new(string name="");
    super.new(name);
  	virtual task body();
      sdram_act_cmd act;
          act= sdram_activate_cmd::type_id::create("req");
      start_item(act);
      if(!act.randomize())begin
          `uvm_error("act_cmd","Randomize Failed")
      finish_item(act);
endclass :act_seq
class wr_seq extends uvm_sequence#(sdram_write_cmd);
  `uvm_object_utils(wr_seq)
sdram_write_cmd write;
    super.new(name);
      write = sdram_write_cmd::type_id::create("write");
      start_item(write);
      if(!write.randomize())begin
          `uvm_error("write_cmd","Randomize Failed")
      finish_item(write);
endclass:wr_seq
class rd_seq extends uvm_sequence#(sdram_read_item);
  `uvm_object_utils(rd_seq)
sdram_read_cmd read;
    super.new(name);
      read= sdram_read_cmd::type_id::create("read");
      start_item(read);
      if(!read.randomize())begin
          `uvm_error("read_cmd","Randomize Failed")
      finish_item(read);
endclass :rd_seq
class ref_seq extends uvm_sequence#(sdram_ref_cmd);
  `uvm_object_utils(ref_seq)
  sdram_ref_cmd refr;
    super.new(name);
      refr= sdram_ref_cmd::type_id::create("ref");
      start_item(refr);
      if(!refr.randomize())begin
        `uvm_error("ref_cmd","Randomize Failed")
      finish_item(refr);
endclass :ref_seq
class pre_seq extends uvm_sequence#(sdram_pre_cmd);
  `uvm_object_utils(_seq)
  sdram_pre_cmd pre;
    super.new(name);
      pre= sdram_pre_cmd::type_id::create("pre");
      start_item(pre);
      if(!pre.randomize())begin
        `uvm_error("pre_cmd","Randomize Failed")
      finish_item(pre);
endclass :pre_seq
// class ul_sequence extends uvm_sequence#(sdram_sequence_item);
//   `uvm_object_utils(ul_sequence)
//     function new(string name = "ul_sequence");
//     super.new(name);
//   endfunction
//   virtual task body();
//   endtask
class sdram_act_wr_rd_pre_seq extends uvm_sequence#(sdram_sequence_item);
  `uvm_object_utils(sdram_act_wr_rd_pre_seq)
    super.new(name);
	act_seq act_sequence;
    wr_seq write_sequence;
    rd_seq read_sequence;
    pre_seq  precharge;
    ref_seq  refresh;
       // ACT
    act_sequence= act_seq::type_id::create("act_sequence");
    start_item(act_sequence);
    if (!act_sequence.randomize()) begin
      `uvm_error("act_cmd", "Randomize Failed")
    finish_item(act_sequence);
        //WRT
   write_sequence = wr_seq::type_id::create("write_sequence");
    start_item(write_sequence);
    if (!write_sequence.randomize()) begin
      `uvm_error("write_seq", "Randomize Failed")
    finish_item(write_sequence);
    //Rd
    read_sequence=rd_seq::type_id::create("read_sequence");
    start_item(read_sequence);
    if (!read_sequence.randomize()) begin
      `uvm_error("read_seq", "Randomize Failed")
    read_sequence.finish_item(read_sequence);
    //Pre
    precharge = pre_seq::type_id::create("precharge");
    start_item(pre);
    if (!precharge.randomize()) begin
      `uvm_error("pre_seq", "Randomize Failed")
    finish_item(precharge);
    // REF
    refresh = ref_seq::type_id::create("refr");
    start_item(refresh);
    if (!refresh.randomize()) begin
      `uvm_error("refr_cmd", "Randomize Failed")
    finish_item(refresh);
class lo_seq extends uvm_sequence#(sdram_sequence_item);
  `uvm_object_utils(lo_seq)
    super.new(name);
  sdram_sequence_item ll;
  sdram_act_wr_rd_pre_seq ul;
      repeat(8) begin
      `uvm_info(get_type_name(),"------------Sending DATA to Driver----------------------",UVM_NONE)
      req = sdram_sequence_item ::type_id::create("req");
      start_item(req);
      if (!req.randomize()) begin
        `uvm_error("MY_SEQUENCE", "Randomize failed.");
      finish_item(req);
  endtask: body
  class sdram_sequencer extends uvm_sequencer#(sdram_sequence_item);
  `uvm_component_utils(sdram_sequencer)
  function new(string name,uvm_component parent);
    super.new(name,parent);
endclass :sdram_sequencer
Now how to give my act_pre_wr_wr_rd_rd_rd_ref and another sequence as act_wr_rd_pre_ref to low level sequence and then to driver?
In reply to Jinay:
That is 300 lines of code, hard to see the forest for all the trees. Can you make an example on HTTP://edaplayground.com ? It should be easy to get it to work, even without a DUT.
One quick note - when randomize() fails, that is a testbench bug, so end the simulation with a uvm_fatal(), not a uvm_error(). Otherwise, you are sending bad stimulus, which does not verify anything.
