event E_TRIGGER1;
module top();
printme(0,3);
printme(1,4);
control();
join
task control();
#10;
->E_TRIGGER1;
task printme(input int i1, input int i2);
if (i1==0) begin
@E_TRIGGER1;
$display("entered (i1==0), value i1=%d, i2=%d", i1, i2);
else begin
$display("entered (else), value i1=%d, i2=%d", i1, i2);
I want to fork the same task multiple times but change their behavior using different input variables.
However, when I run the example above, the simulator produces the following output:
entered (else), value i1= 1, i2= 4
entered (i1==0), value i1= 1, i2= 4
I don’t understand how the second line can be generated with i1=1 and i2=2. It seems to me as if these variables are overwritten while waiting for the event by the second fork of the task. Doesn’t have a forked task it’s own copy of the input variables on it’s stack? If I remove the @E_TRIGGER1; the output is as I expect it also to be in the example:
entered (i1==0), value i1= 0, i2= 3
