I want to probe some signals inside DUT.
I have 64 “stream_gates” inside the DUT. I wanted to implement a genvar variable to access a particular signal inside each of the gates…But it gives me below ERROR:
My code >>>>>>>>>>>>>>>>
genvar ki;
for ( ki=0; ki<63; ki++) begin
if(sw_tb_top.u_dut_top.u_swsys.stream_gates[ki].u_psfp_sg.gate_enabled != 1’b1)`uvm_error(“RDB_CHECK_FAIL”,$psprintf(“gate_enable[%0d] is not equal to 1’b1. Expected is 1’b1”,ki));
endError >>>>>>>>>>>>
Verilog keyword ‘genvar’ is not expected to be used in this context.
Can you please help me figure out how I can do this? Can’t I use genvar inside a class??
