How to synchronize between task sequence and uvm end of test?
When I ran a sequence from a task through the UVM test, the UVM objection mechanism propagation was broken. UVM simulation was terminated abnormally. Especially the driver does not finished correctly after my_test.my_run(32’h1234, 32’h12341234);
rnd_seq_c  rnd_seq;
    super.build_phase(phase);
    rnd_seq = rnd_seq_c::type_id::create("rnd_seq", this);
 phase.raise_objection(this);
     my_test.my_run(32'h1234, 32'h12341234);
 join
 phase.drop_objection(this);
This is my sequence.
class rnd_seq_c  extends vseq_c;
`uvm_objection_utils(rnd_seq_c)
function new(string name="rnd_seq_c ");
    super.new(name);
endfucntion
virtual task my_run( bit [31:0] addr, bit [31:0] data);
    rnd_item= rnd_seq_item::type_id::create("rnd_item");
    start_item(rnd_item,,rnd_seqr);
    rnd_item.data = data;
    rnd_item.addr = addr;
    finish_item(item);
pipelined driver used.
class my_pipelined_driver extends uvm_driver #(rnd_seq_c  );
  `uvm_component_utils(my_pipelined_driver)
  /// Virtual Interface
  virtual my_interface my_if;
  /// Constructor
    super.new(name, parent);
  endfunction: new
    if(!uvm_config_db #(virtual my_interface)::get(this, "", "vif", my_if))begin
      `uvm_fatal(get_type_name(), "Virtual Interface not set in my_driver")
      `uvm_info(get_type_name(), "Virtual Interface set in my_driver", UVM_LOW)
  /// Semaphore Declaration
  semaphore pipeline_lock = new(1);
  /// Run Phase Task
  task run_phase (uvm_phase phase);
  @(posedge my_if.RESETn);
  @(posedge my_if.HCLK);
    do_pipelined_transfer;
  join
  endtask: run_phase
  /// do_pipelined_transfer task
  task automatic do_pipelined_transfer;
//  rnd_seq_c   req;
  forever begin
    pipeline_lock.get();
    accept_tr(req, $time);
    void'(begin_tr(req, "pipelined_driver"));
    my_if.HADDR <= req.HADDR;
    my_if.HWRITE <= req.HWRITE;
    my_if.HBURST <= req.HBURST;
    while(!my_if.HREADY == 1) begin
  // Command phase ends here
  // Unlock semaphore
  pipeline_lock.put();
  // Data phase starts here
  if (req.HWRITE == 0) begin
  while(my_if.HREADY != 1) begin
    req.HRDATA = my_if.HRDATA;
    $display("!!Driver:read_data: %0h", req.HRDATA);
    req.HRESP = my_if.HRESP;
  else begin
    my_if.HWDATA <= req.HWDATA;
  // Return the Request as Response
    seq_item_port.item_done(req);
    end_tr(req);
  endtask: do_pipelined_transfer
endclass: my_pipelined_driver
How do I run until the end of simulation from an abnormal termination?
join
If I use objection into the sequence,
    super.new(name);
endfucntion
    uvm_phase phase;
    finish_item(item);
I get the NULL pointer dereference. Error. What if we start the sequence through task then how do I correctly start the sequence until end of test?
In reply to UVM_LOVE:
You can’t use custom task calls and expect that UVM will function correctly. You need to execute sequences with the seq.start() call and use body() in your sequence.
In reply to cgales:
So I implemented as your recommend.
This is my test
rnd_seq_c    rnd_seq;
write_seq_c  write_seq;
    write_seq  = write_seq_c::type_id::create("write_seq", this);
 write_seq.start(rnd_env.rnd_vseqr);
I move the task in base sequence,
class vseq_c  extends uvm_sequence;
`uvm_objection_utils(vseq_c  )
function new(string name="vseq_c");
    super.new(name);
endfucntion
    finish_item(item);
and I extended it into the write_seq.
class write_seq extends vseq_c;
task body();
    my_run('h4, 'h1111_0000);
When I ran " write_seq.start(rnd_env.rnd_vseqr); " result is the same as before. this style also need extra drain time.
Could you guide me with example code?
Without seeing the entire testbench, it’s difficult to provide an accurate assessment.
Your pipelined driver seems strange, with two of the same task running in parallel. Have you looked at the UVM Cookbook section on pipelined drivers?
In reply to cgales:
I’ve just updated with the new code as the below,
The “isr_seq” sequence works in the background while bseq[0] works.
Every 200ns, ISR sequence starts from monitor trigger.
But there is one problem which is “ISR finish” does not finish after “ISR start”.
So I implemented raise/drop objection in the sequence. but this also does not work.
I thought that the objection mechanism would have controlled in sequence but even objection in sequence would does not work.
UVM_INFO testbench.sv(33) @ 1500: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] ISR start
UVM_INFO testbench.sv(41) @ 1500: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] data = 0x000f
UVM_INFO testbench.sv(41) @ 1550: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] data = 0x000f
UVM_INFO testbench.sv(41) @ 1600: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] data = 0x000f
UVM_INFO testbench.sv(47) @ 1650: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] ISR finish
UVM_INFO testbench.sv(93) @ 1650: uvm_test_top.env_o.agt.seqr@@bseq          0 [base_seq] data = 0x000d
UVM_INFO testbench.sv(33) @ 1700: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] ISR start
How do I correctly finish the sequence in this case?
`include "uvm_macros.svh"
import uvm_pkg::*;
`include "seq_item.sv"
`include "sequencer.sv"
`include "monitor.sv"
`include "driver.sv"
`include "agent.sv"
`include "env.sv"
class my_isr_sequence extends uvm_sequence #(seq_item);
  seq_item req;
  seq_item rsp;
  uvm_event e;
`uvm_object_utils(my_isr_sequence)
  function new(string name = "my_isr_sequence");
    super.new(name);
 virtual task pre_start();
       if(starting_phase != null)
      starting_phase.raise_objection(this);
  endtask: pre_start
task body();
  e = uvm_event_pool::get_global("INT");
  forever begin
    e.wait_trigger();
    `uvm_info(get_type_name(), "ISR start", UVM_MEDIUM)
    grab();
    repeat(3) begin
      req = seq_item::type_id::create("req");
      start_item(req);
      if(!req.randomize() with {req.data == 4'hf;}) begin
        `uvm_fatal(get_type_name(), "randomize fail");
      `uvm_info(get_type_name(), $sformatf("data = 0x%h", req.data), UVM_MEDIUM)
      finish_item(req);
      get_response(req);
    ungrab();
    e.reset();
    `uvm_info(get_type_name(), "ISR finish", UVM_MEDIUM)
  task post_body();
    // drop objection if started as a root sequence
      starting_phase.drop_objection(this);
class my_seq_item_c extends uvm_sequence_item;
rand bit [7:0] data;
`uvm_object_utils(my_seq_item_c)
  function new(string name = "my_seq_item_c");
    super.new(name);
class base_seq extends uvm_sequence #(seq_item);
  process p[$];
  process pstate;
  seq_item req;
  seq_item rsp;
  std::process p1,p2,p3;
  `uvm_object_utils(base_seq)
  function new (string name = "base_seq");
    super.new(name);
  task body();
    for(int i=0; i<10; i++) begin
//    repeat(10) begin
//    `uvm_info(get_type_name(), $sformatf("Base seq: Inside Body:%0d",i), UVM_LOW);
    start_item(req);
     if (!req.randomize() with { req.data < 4'hF; }) begin
      `uvm_fatal(get_name(), "randomization fail");
      `uvm_info(get_type_name(), $sformatf("data = 0x%h", req.data), UVM_LOW)
    finish_item(req);
    get_response(rsp);
    // or
    //$cast(req, create_item(seq_item::get_type(), m_sequencer, "req"));
class base_test extends uvm_test;
  env         env_o;
  base_seq    bseq[3];
  my_isr_sequence isr_seq;
  `uvm_component_utils(base_test)
  function new(string name = "base_test", uvm_component parent = null);
    env_o = env::type_id::create("env_o", this);
    //foreach(bseq[i]) begin
      bseq[0] = base_seq::type_id::create( $sformatf("bseq%d", 0), this);
      isr_seq = my_isr_sequence::type_id::create("isr_seq", this);
    //end
      isr_seq.start(env_o.agt.seqr);
    join_none
    bseq[0].start(env_o.agt.seqr);
    //#1000;
module tb_top;
    run_test("base_test");
this is monitor to trigger to events
class monitor extends uvm_monitor;
  `uvm_component_utils(monitor)
  uvm_analysis_port #(seq_item)  mon_analysis_port;
  function new(string name = "monitor", uvm_component parent = null);
    super.new(name ,parent);
    mon_analysis_port = new("mon_analysis_port", this);
    uvm_event e;
    super.run_phase(phase);
    forever begin
      #100;
      e.trigger();
If you want your ISR sequence to always block phase completion, you should raise/drop the objection within the body() and don’t use pre_start()/post_body().
In reply to cgales:
Even if I implement raise/drop objection in body() but that’s not finished at the “ISR finish”
UVM_INFO testbench.sv(48) @ 1450: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] ISR finish
UVM_INFO testbench.sv(98) @ 1450: uvm_test_top.env_o.agt.seqr@@bseq          0 [base_seq] data = 0x0007
UVM_INFO testbench.sv(35) @ 1500: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] ISR start
UVM_INFO testbench.sv(43) @ 1500: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] data = 0x000f
UVM_INFO testbench.sv(43) @ 1550: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] data = 0x000f
UVM_INFO testbench.sv(43) @ 1600: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] data = 0x000f
UVM_INFO testbench.sv(48) @ 1650: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] ISR finish
UVM_INFO testbench.sv(98) @ 1650: uvm_test_top.env_o.agt.seqr@@bseq          0 [base_seq] data = 0x000d
UVM_INFO testbench.sv(35) @ 1700: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] ISR start
UVM_INFO testbench.sv(43) @ 1700: uvm_test_top.env_o.agt.seqr@@isr_seq [my_isr_sequence] data = 0x000f
This is what I implemented with objection.
task body();
  forever begin
    e.wait_trigger();
    grab();
    repeat(3) begin
      start_item(req);
      finish_item(req);
      get_response(req);
    ungrab();
    e.reset();
