How to "start" the sequence/s?
Dave,
I aware that seq_lib is not mandatory for this test. I have another seq_lib_test, which is using seq_lib (randomly selecting sequences in different order).
Yes, I agree “global_stop_request()” added for no reason. I was explaining that to my peer, but forgot to comment it out here.
But I did not understand “no reason” for raise/drop objection. I have added raise/drop objection in pre/post body of each sequences, to hole the control from the sequences.
Here I have cases as below…
Case 1:
  1. raise objection from uvm_test run_phase
  2. raise objection from seq1
  3. raise objection from seq2
  4. drop objection from seq2
  5. drop objection from seq1
  6. drop objection from uvm_test run_phase
Case 2:
  3. drop objection from seq1
  4. some delay
  5. raise objection from seq2
  6. drop objection from seq2
  7. drop objection from uvm_test run_phase
Case 3:
  4. drop objection from seq1
  5. drop objection from uvm_test run_phase
Case 4:
  4. drop objection from uvm_test run_phase
  5. <seq2 did not started yet, but test done>
How to achieve above scenarios??
At present, I’m using random delay (#1000;) from the test.
sometimes, sequence/s did not start, till end of delay, and test ends.
John
