How to show coverage results in reparate Instances
I used a reusable embedded covergroup in a class, which has an argument as a ref variable. This covergroup is then used in separate classes. However, after the simulation is completed, the coverage results are only displayed in the embedded covergroup class. I need to obtain coverage results for the separate instances. Below, I will show the code I am working with.
Embedded Covergroup
common_coverge.svh
class common_coverage;
    ​covergroup data_cg (ref logic [31:0] data);
        ​CP_DATA : coverpoint data {
            bins zerobin = {0};
            bins endValue     = {32'hffffffff};
    endgroup
    ​function new(ref logic [31:0] data);
        this.data_cg = new(data);
    endfunction: new
tx_funcational_coverage.svh
class tx_functional_coverage extends uvm_subscriber #(tx_seq_item);
    `uvm_component_utils(tx_functional_coverage)
    logic [31:0]        data;
    common_coverage     tx_cover;
    ​function new(string name="tx_functional_coverage",uvm_component parent);
        super.new(name,parent);
        tx_cover = new(this.data);
    endfunction: new
    ​virtual function void write(tx_seq_item t);
        t.get_data(this.data);
        tx_cover.data_cg.sample();
    endfunction: write
endclass : tx_functional_coverage
rx_functional_coverage.svh
class rx_functional_coverage extends uvm_subscriber #(rx_seq_item);
    `uvm_component_utils(rx_functional_coverage)
    logic [31:0]        data;
    common_coverage     rx_cover;
    ​function new(string name="rx_functional_coverage",uvm_component parent);
        rx_cover = new(this.data);
    endfunction: new
    ​virtual function void write(rx_seq_item t);
        rx_cover.data_cg.sample();
    endfunction: write
endclass : rx_functional_coverage
Use the per_instance option.
    option.per_instance=1;
