How to set macro having repeated text
Hello Gurus,
I am looking for easier way to declare following localparams pattern by means of using SV macros:
localparam integer myvar [5:0] = '{myvar_5,
                                   myvar_4,
                                   myvar_3,
                                   myvar_2,
                                   myvar_1,
                                   myvar_0};
// There are more than 20 such declarations with different lengths, say N like so in code
//localparam integer somevar [N-1:0] = '{somevar_<N-1>,
//                                       somevar_2,
//                                       somevar_1,
//                                       somevar_0};
I would ideally like to have a SV macro `DECLARE_TB_ARRAY(var_, length_, type_) which can be used for declarations easily. But SV macros doesn’t support repeated text by means of conditional check and loops. Is there any clever alternate?
Thanks.
In reply to stupidkris1010:
Cannot be done in SystemVerilog using macros.
I would try figure out a way not to have individual signal names and use an array instead.
You could also look for editor scripts to generate the code for you.
