Hi every one ,
Whenever we use %p to print unpacked data type, The Tool will print all variables in Decimal format. But how to print all variable in Hexdecimal?
Please provide me info to achieve.
Regards/Thanks
kbkdec15
Hi every one ,
Regards/Thanks
kbkdec15
The LRM does not specify a way to do this (see Mantis 2580), but with Modelsim/Questa 10.2 you can use $displayb/o/h and similar tasks to select the radix. Please note that %p is a quick but crude way to print an object; you should put some effort in to properly format it.
I am printing the OBJECT of my class.
The class have FIELDS and some constraints in it.
If i want to print only FIELDS and NOT CONSTRAINTS, is there any method to do so ?
Sorry for silly question.
In reply to Balu_15:
If you print “int signed” data type with “%p”, then it shows in Decimal. But if you print “int unsigned” then it shows in Hexadecimal.
Convert Signed into unsigned, then print.
Also its not good thing to use %p, but just temporary solution!!!
