class abc_test extends abc_base_test;
`uvm_component_utils(abc_test)
string report_id = "abc_test";
rand int write_client_select;
write_client_select = ($urandom_range(1,10));
I want to select random values from different set of values for “int write_client_select” such as 0,2,4,7,12,16,… and not range.
What is the way to do it?
In reply to Dharak Modi:
Try this…
randomize(write_client_select) with { write_client_select inside {0,2,4,7.12.16}; };
Pavan
In reply to pavan yala:
randomize (write_client_select) with { write_client_select inside { 1,3,4,7,8,9,10,11,12,13,14,15,17,20,21,22,23,24,25,27,29,30};};
Pavan, I tried this but getting compilation error, “**): near “(”: syntax error, unexpected ‘(’, expecting IDENTIFIER or ‘=’.****”
The call to randomize must be inside a class method. Can you show your complete code.
I tried in Build phase and it worked. Thanks Dave.
Pavan, Thanks a lot buddy. It’s working for me.
