How to select specific bits from integer and assign it to queue of byte
I have the following code:
   rand byte unsigned data[$];
   int burst_width, raw_data;
burst_width value is calculated on the fly.
I have to assign
raw_data[(burst_width*8-1):0]
to data.
I tried the follwong:
data = raw_data >> (burst_width*8);
But in system Verilog we can’t assign packed array to queue.
In reply to Sarit8r:
Use the streaming pack/unpack operator
    raw_data = 'h01234567;
    $displayh("raw_data %h",raw_data);
    for(burst_width=1;burst_width<5;burst_width++) begin
      data = {>>{raw_data with [(burst_width*8)-1:0]}};
      $displayh("%0p",data);
If you want to convert an integer (raw_data) into a packed array of bytes (data), you need to handle the bit extraction and packing yourself. Since you are working with a dynamic array of bytes, you can do this in a loop. Here is the way to do it :
// ... Assume burst_width is set somehow ...
// Calculate the size of the data array based on burst_width
data = new[burst_width];
// Pack raw_data into data
int i;
for (i = 0; i < burst_width; i++) begin
    data[i] = raw_data[8*i +: 8]; // Extract 8 bits at a time
