While using Parameterised Class , i am getting this error
reporter [TPRGED] Type name ‘driver#(NO_OF_DEVICE)’ already registered with factory. No string-based lookup support for multiple types with the same type name.
Most likely because you used uvm_component_utils instead of uvm_component_param_utils to register with the factory. See Not registered in factory....Error message in parameterized class | Verification Academy for more details.
Thanks dave,
It works
In reply to sidharth.sankar77:
Now I am getting problem, when i used uvm_component_param_utils and i extended another driver from this driver and in test case try to override the new driver with the old one, it is not working.
If i only use uvm_component_utils ,it is working but the warning is still there. Pls help me to remove the warning.
You will need to show us how you pass the parameters in your class definitions, and how you use `uvm_component_utils
`define param_value
parameter value= `param_value
class driver1#(int W = 1 ) extends uvm_component;
`uvm_component_utils(driver1#(W))
function new ( string name = "driver1" , uvm_component p = null);
super.new(name, p);
..... some statements .....
task reset_phase(uvm_phase phase);
endtask : reset_phase
task main_phase(uvm_phase phase);
......... some statements .....
endtask : main_phase
class driver2#(int W= 0) extends driver1;
`uvm_component_utils(driver2#(W))
function new ( string name = "driver2" , uvm_component p = null);
super.new(name, p);
class agent#(int W= 0) extends uvm_agent;
`uvm_component_utils(agent#(W))
driver1#(value) c3;
function new ( string name ="agent", uvm_component p = null);
super.new(name, p);
c3 = driver1#(value)::type_id::create("c3", this);
class env#(int W= 0) extends uvm_env;
`uvm_component_utils(env#(W))
agent#(value) a;
function new ( string name ="env", uvm_component p = null);
super.new(name, p);
a = agent#(value)::type_id::create("a", this);
class base_test extends uvm_test;
`uvm_component_utils(base_test)
env e;
function new ( string name = "test", uvm_component p = null);
super.new(name, p);
e = env#(value)::type_id::create("e", this);
class test extends base_test;
`uvm_component_utils(test)
super.new(name, p);
set_type_override_by_type( driver1#()::get_type(), driver2#()::get_type());
super.build_phase(phase);
run_test("test");
I am passing param_value from command line.
if i am using uvm_component_param_utils driver2 is not overiding driver1. But if i use uvm_component_utils it working but the warning comes.
You never showed me what value you passed to param_value. But I’ll assume its something other than the default value 1 used to declare the class driver1. Let’s say param_value is 3.
If you are using Questa, you should have gotten a warning message for this line:
(vlog-2181) Use of a parameterized class 'driver1' as a type creates a default specialization.
This means driver2 is really an extension of driver1#(1).
In your agent, you declared c3 as
driver1#(value) c3;
If value is 3, you are asking to create an object of type driver1#(3).
However your override statement is
which will set an override for driver#(1), not driver#(3). There is no override for driver#(3). Remember that ‘driver1’ by itself is not an actual type. ‘driver1’ plus a specific set(implicit or explicit) of parameters is a type. Please read Using parameterized classes & factories: Object-oriented verification
