For Example:
int a[100];
foreach(a[i]) begin
a[i]=i;
Now i want to randomly pick any of two element values from the above array?
is there any method in an array?
For Example:
int a[100];
foreach(a[i]) begin
a[i]=i;
There are many ways you could do this, but simplest would be to use a.shuffle(), then pick a[0] and a[1].
You could also do
int val1, val2;
std::randomize(val1,val2) with {unique {val1,val2}; val1 inside {a}; val2 inside {a};};
How to pick an element from an associative array randomly?
I have a requirement that I need to read from an already written location. I store the start address of that location as associative array index and length of that write as that index’s element.
int sa_and_dwlen_arry[int];
I will check the size before a read, but how to chose a start address and length randomly? Can we shuffle an associative array also? If so, the element should also move along with index, right?
Or I need to use array of struct where struct will contain both start address and length?
-mpattaje
In reply to pkoti0583:
Hello pkoti0583!!!
Here is one way to solve the question:
class packet;
rand int array [];
constraint array_elements_limit {
foreach(array[i]) {
array[i] inside {[1000:2000]};
constraint unique_elements_inside {
foreach(array[i]) {
unique {array};
constraint array_size_limit {array.size inside {100};}
module pick_two_elements;
initial
packet pkt = new();
pkt.randomize();
$display("\nThe size of the array is : %0d", pkt.array.size);
foreach(pkt.array[i])
$display("\narray[%0d] = %0d",i,pkt.array[i]);
$display("\nThe two random values picked from the array are : ");
repeat(2)
$display("\n%0d",pkt.array[$urandom_range(0,pkt.array.size - 1)]);
$display("------------------------------------------------------------------");
Hope it helps :)
