How to put UVM environment into OVM bench
I have one IP which is tested with UVM, but the top level environment is OVM, how to put UVM environment into OVM? Thanks
In reply to webskyforest:
OVM and UVM are not able to co-exist. I recommend converting the OVM environment to UVM and continue from there.
In reply to cgales:
Thanks, I may need to convert UVM environment to OVM since others are OVM. Is there a easy way to convert UVM to OVM?
There is a script that can do some of it, and it depends on how old your OVM code is.
See OVM2UVM | Verification Academy
Thanks, good reference.
