Your code as written doesn’t compile in any of the four simulators on EDA Playground. Specifically, the arrays of verif_if and chk_intf in top_if are incorrect as they should be arrays of instances, which is not what is written.
I recommend using a parameter to verif_if to specify the instance_num instead of an int, as a parameter is a constant while a variable is not.
I will be able to do it by parameter but I will have to modify interface definition for every project and many files where I am getting this interface.
Because ,Its working fine with one instance of ck_intf interface.
Interface instances are considered hardware constructs (with the exception of virtual interface handles), so you can’t use variables to index within an array of interfaces. During elaboration, the indexes need to be constant, hence why you can’t use a variable.
It works when you have a single interface since it is a constant reference.
Using a parameter will only affect the interface definition, and only in projects with this specific use case.
interface top_if();
//Logics
chk_intf ck_intf[2]();
genvar k;
generate
for(k=0;k < 2 ; k++) begin : verif_intf_inst
verif_if#(.INSTANCE_NUM(k)) ve_intf ();
endgenerate
endinterface
interface verif_if ();
parameter int INSTANCE_NUM;
//trying to access signals of chk_intf
wait(ck_intf[INSTANCE_NUM].train_en[31:0] == 5); //Getting error "Illegal Operand for constant expressions [4(IEEE)]"
$display("Training has been started");
endinterface
