Hello all,
I am building a UVM verification environment for a VHDL entity that has 1 generic. This VHDL design is encapsulated into a SV wrapper module which is parametrized. This parameter/generic is called C_COUNTER_NBIT and is used to define the size of several I/O and internal signals.
The idea is to be able to launch a simulation that is able to randomized this parameter during elaboration. I use vivado for my simulation and I’m able to specify a value in the command for the parameter of my top module. Then I pass it to the wrapper and then to my VHDL module.
The issue I have is: I can’t manage to set the parameter of my virtual interface. I tried to set the value of my interface parameter when declaring the virtual interface to the config db and/or in the instanciation of actual interface inside my wrapper but I always get the following error: incompatible complex type assignment
Here is the code I use
Thanks in advance for your answers.
module top#(C_COUNTER_NBIT = 16);
`include "uvm_macros.svh";
import uvm_pkg::*;
import tb_pkg::*;
frame_generator_wrapper #(.C_COUNTER_NBIT(C_COUNTER_NBIT)) u_frame_generator_wrapper();
uvm_config_db #(virtual Interface#(.C_COUNTER_NBIT(C_COUNTER_NBIT)))::set(null, "*", "Interface", u_frame_generator_wrapper.fr_gen_itf);
uvm_top.finish_on_completion = 1;
run_test("Tc_frame_generator");
endmodule: top
interface Interface #(C_COUNTER_NBIT = 8)(input bit clk);
//Signals
logic rst;
logic[C_COUNTER_NBIT-1:0] cfg_hor_sync_pulse;
clocking driver_cb @(posedge clk);
output #1 rst, cfg_hor_sync_pulse;
endclocking: driver_cb
endinterface: Interface
module frame_generator_wrapper#(C_COUNTER_NBIT = 16);
bit clk;
Interface fr_gen_itf(.clk);
//I also tried this but it not working neither
//Interface #(.C_COUNTER_NBIT = C_COUNTER_NBIT)fr_gen_itf(.clk);
frame_generator #(
.G_COUNTER_NBIT(C_COUNTER_NBIT)
) u_frame_generator(
.clk(clk),
.rst(fr_gen_itf.rst),
.cfg_hor_sync_pulse(fr_gen_itf.cfg_hor_sync_pulse)
initial begin: clock_generator
clk = 0;
forever begin
#(C_CLK_PERIOD/2);
clk = ~clk;
end: clock_generator
endmodule: frame_generator_wrapper
