How to ignore 'rest of bins' in cross coverage
I’m trying to write coverpoints for specific sequences of instructions in a pipeline:
pipe_stage_0: coverpoint({stage_0_is_inst_A, stage_0_is_inst_B})
   bins IS_A = {2'b10};
   bins IS_B = {2'b01};
   bins IS_NEITHER = {2'b00};
pipe_stage_1: coverpoint({stage_1_is_inst_A, stage_1_is_inst_B})
pipe_stage_2: coverpoint({stage_2_is_inst_A, stage_2_is_inst_B})
pipe_inst_cross: cross pipe_stage_0, pipe_stage_1, pipe_stage_2
   bins A_B_NEITHER = binsof(pipe_stage_0.IS_A) && binsof(pipe_stage_1.IS_B) && binsof(pipe_stage_2.IS_NEITHER);
   bins A_A_NEITHER = binsof(pipe_stage_0.IS_A) && binsof(pipe_stage_1.IS_A) && binsof(pipe_stage_2.IS_NEITHER);
   bins NEITHER_A_B = binsof(pipe_stage_0.IS_NEITHER) && binsof(pipe_stage_1.IS_A) && binsof(pipe_stage_2.IS_B);
   ... // a few other explicit sequences I want to include
   // somehow ignore remainder bins?
The coverage report certainly shows these explicit bins, but unfortunately it also autogenerates every other combination of the cross. (The latter greatly outnumbers the former.)
How can I ignore those remainder bins? I have tried
ignore_bins ignore_invalid = default;
but it seems this is not allowed in a cross statement.
In reply to atashinchi:
The current LRM only allows combining autogenerated cross bins, or ignoring them. You have a couple of choices:
Use another coverpoint instead of a cross
pipe_inst_cross: coverpoint  { stage_0_is_inst_A, stage_0_is_inst_B,
                               stage_1_is_inst_A, stage_1_is_inst_B,
                               stage_2_is_inst_A, stage_2_is_inst_B }
   bins A_B_NEITHER = { {2'b10, 2'b01, 2'b00} };
   bins A_A_NEITHER = { {2'b10, 2'b10, 2'b00} };
   bins NEITHER_A_B = { {2'b00, 2'b10, 2'b01} };
Use more coverpoints instead of more bins
pipe_stage_0_IS_A: coverpoint({stage_0_is_inst_A, stage_0_is_inst_B})
pipe_stage_0_IS_B: coverpoint({stage_0_is_inst_A, stage_0_is_inst_B})
pipe_stage_0_IS_NEITHER: coverpoint({stage_0_is_inst_A, stage_0_is_inst_B})
pipe_stage_1_IS_A: coverpoint({stage_1_is_inst_A, stage_1_is_inst_B})
pipe_stage_2_IS_NEITHER: coverpoint({stage_2_is_inst_A, stage_2_is_inst_B})
Then cross the specific coverpoints you need.
A_B_NEITHER: cross pipe_stage_0_IS_A,pipe_stage_1_IS_B, pipe_stage_2_IS_NEITHER;
A_A_NEITHER: cross pipe_stage_0_IS_A,pipe_stage_1_IS_A, pipe_stage_2_IS_NEITHER;
NEITHER_A_B: cross pipe_stage_0_IS_NEITHER,pipe_stage_1_IS_A, pipe_stage_2_IS_B;
Note there is an enhancement coming in the next revision of the IEEE 1800 SystemVerilog LRM with a new option
cross_retain_auto_bins
that prevents autogeneration of cross bins. Ask your tool vendor about support.
If you insist on default-bin like behavior within cross , here is Dave’ solution using ignore_bins
