How to identify which master has initiated the transaction in UVM TB
Hello
I have a multi master and multi slave environmnet . In testcases there are two sequencers that are set one for master_0 and master_1.
How do you identify which master has sent the transaction and slave responded in a scoreboard while comparing ?
In reply to verific_engi:
We don’t know anything about your transactions. You need to tell us why it matters.
Sometime you can encode serial numbers in your transactions to map transactions.
The transactions here are of AXI and master 1 or master 0 use these transactions . In test case master is decided on type of seqr started before starting particular sequence.
I use
m_sys_config_seq.set_axi_seqr (n1_seqr); for master 1
  m_sys_config_seq.set_axi_seqr (n_seqr);  for master 0
then in the test case
m_sys_config_seq.axi_write32('hC1000000, wr_data);
I can print which master using it from test case but what about to print the master curretly sending transaction
You should use as a transaction member a master_id. Transactions coming from master0 get the id=0
and transactions from master1 get the id=1. Then you can identify which transaction comes from which master.
Will try that if cadence transaction has that field as I have no permission to edit the class
You can simply extend the base class.
