In my current verification project, one of the requirements from the DUT is that at a certain state during its operation, it must ignore all write sequences it receives on the AXI-4 Lite bus, meaning if the verification environment sends a write sequence to it, the DUT will perform the handshake and receive the data, but will not insert it into its registers.
My verification environment communicates on that AXI-4 Lite bus using a RAL block.
When configuring the registers in the RAL block I set them to have “RW” access.
My issue is that I don’t know how to periodically prevent the RAL block from predicting when writing to the DUT.
At first I was thinking about changing the access to the registers in the RAL to be “RO”, but I realised it is impossible during simulation. I assumed the register.write() function would have a parameter the would disable prediction but that’s not the case also.
The only solution I could find is to use register.do_write(), which I haven’t implemented yet because it seems “unclean” and I didn’t know if it’s a good way to do it.
If the write data wouldn’t be reflected in the registers then the BResp returned wouldn’t be OKAY ( d0). I believe in such cases DUT would return SLVERR ( 'b10 )
Within bus2reg function on seeing the SLVERR, rw.status would be assigned UVM_NOT_OK
If you are using auto_prediction ( set_auto_predict() / set_auto_predict(1) )
// During end of uvm_reg::do_write
if (system_map.get_auto_predict()) begin
uvm_status_e status;
if (rw.status != UVM_NOT_OK) begin
sample(value, -1, 0, rw.map);
m_parent.XsampleX(map_info.offset, 0, rw.map);
status = rw.status; // do_predict will override rw.status, so we save it here
do_predict(rw, UVM_PREDICT_WRITE); // My comment :: Updates mirrored values
rw.status = status;
This does up end up updating the mirrored values with the write data (based on register access policy of register fields) even though the status of write operation is UVM_NOT_OK
What if you were to use explicit prediction ( with no TLM connection from monitor to predictor component ) during that certain state and revert to auto prediction once it leaves that state ?
It appears using “register.field.set_access(“RO”)” is working. I previously used set_access() on the uvm_reg instead of the uvm_reg_field, and for that reason it wasn’t working for me, but it’s all good now.
@Praveen_Kakodra Thank you for your comment, you did open my eyes to the fact that the DUT puts out bresp = 0 when it shouldn’t.
I am aware that there are restrictions on calling RAL APIs once root_reg_block.lock_model() is called. Not sure if calling set_access is one of the restricted ones
