class base_seq extends uvm_sequence#(RV_seq_item);
`uvm_object_utils(base_seq)
RV_seq_item req;
//Constructor
function new(string name = "base_seq");
super.new(name);
virtual task body();
req = RV_seq_item::type_id::create("req");
wait_for_grant();
if(!req.randomize())
`uvm_error("body", "randomization failure for item")
send_request(req);
wait_for_item_done();
class regression_seq extends base_seq;
string rly_opt, rlyon, cmd_chprly;
int i_rly_opt, i_rlyon, i_cmd_chprly;
`uvm_object_utils_begin(regression_seq)
`uvm_field_int(a_rly_opt,UVM_ALL_ON)
`uvm_field_int(a_rlyon,UVM_ALL_ON)
`uvm_field_int(a_cmd_chprly,UVM_ALL_ON)
`uvm_field_string(rly_opt,UVM_ALL_ON)
`uvm_field_string(rlyon,UVM_ALL_ON)
`uvm_field_string(cmd_chprly,UVM_ALL_ON)
`uvm_object_utils_end
//`uvm_object_utils(regression_seq)
uvm_cmdline_processor cmd_args;
//Constructor
function new(string name = "regression_seq");
super.new(name);
cmd_args = uvm_cmdline_processor::get_inst();
cmd_args.get_arg_value("+RLY_OPT",rly_opt);
//`uvm_info(get_type_name(),"CALLING -------------- command line arguments rly_opt", UVM_LOW)
cmd_args.get_arg_value("+RLYON",rlyon);
// `uvm_info(get_type_name(),"CALLING -------------- command line arguments rlyon", UVM_LOW)
//end
cmd_args.get_arg_value("+CMD_CHPRLY",cmd_chprly);
// `uvm_info(get_type_name(),"CALLING -------------- command line arguments cmd_chprly", UVM_LOW)
//end
a_rly_opt=rly_opt.atoi();
a_rlyon=rlyon.atoi();
a_cmd_chprly=cmd_chprly.atoi();
`uvm_do_with(req,{FD_RLYON == a_rlyon; F_RLY_OPT == a_rly_opt; CMD_CHPRELAY == a_cmd_chprly;})
+RLY_OPT=0 +RLYON=1 +CMD_CHPRLY=0
im getting these errors can you please help for that one
‘a_rly_opt’: undeclared identifier
a_rly_opt is not a class item.
