in the middle of ( seq driver communication ) I have to access some variables(updated during middle of seq driver communication in sequencer) in driver.
Not sure how you exactly update it from within the sequencer but assuming you do - recall that the req (seq_item) is passed by reference (by default) between SQR-DRVR, hence if you update the req while DRVR is still accessing, it should reflect on its own (though never tried that).
// Within your driver component
my_sequencer #( req_type , rsp_type ) sqr_h ; // Same sequencer specialization as in your agent
task main_phase( uvm_phase phase);
uvm_sequence_base sqr_base ;
forever begin
seq_item_port.get_next_item( req );
sqr_base = req.get_sequencer(); // Returns 'm_sequencer' of type uvm_sequencer_base type
$cast( sqr_h , sqr_base ) ; // Downcast
// Now you can access my_sequencer properties
// Eg: sqr_h.property1 = <value> ;
seq_item_port.item_done( < rsp_type_optional> );
Btw I am curious regarding the intention behind the access.
(1) Have you added user-defined properties in your sequencer ?
(2) What purpose do these properties serve ?
(3) How are these sequencer properties assigned ?
The prototype of the tasks get and get_next_item within class uvm_sequencer are defined as
task uvm_sequencer::get_next_item(output REQ t);
task uvm_sequencer::get(output REQ t);
I believe the request ( as well as response ) are pass by value rather than pass by reference
- yes, I have took some properties
- based on updated properties in sequencer i have to send response from driver
- I have took some properties , which are updated from monitor during (seq-drv communication)
In SV, class objects are pass by ref and since REQ/RSP are class handles, they are passed by ref (and user has to copy/clone at destination if needed).
There is a distinction when an object is passed by reference v/s by value ( default ).
class base;
bit [1:0] a ;
base b_h ;
b_h = new();
b_h.a = 1;
$display("b_h is %0p",b_h);
func( b_h );
func_ref( b_h );
function automatic void func ( base b);
b = new();
b.a = 3;
function automatic void func_ref ( ref base b);
b = new();
b.a = 3;
For pass by reference the argument direction must be explicit ‘ref’ type which I don’t observe in the UVM base classes for the sequence and sequencer.
