Let’s say I have the following class, I want to randomly fill the array with unique element and yet suffice the sum constraint.
Instead of using nested foreach constraint, as it will significantly slow down the simulation, is there any other way to do this?
class array_wrapper;
rand bit[7:0] array[10];
constraint c_sum{array.sum()<1024;};
P.S:
One method I can think about is to add a helper class with randc variable as we normally used in generating unique array and then redo the randomization if the sum exceeds 1024.
class help_c;
randc bit[7:0] a;
help_c helper;
do begin
helper = new();
foreach(array[i])begin
helper.randomize();
array[i]=helper.a;
while(array.sum()<1024);
Just wondering if there is a more neat way to do this?
Thanks in advance,
Hao
