I need to list all the indices of an associative array using any of the built in methods. I tried using array.unique(), but dosen’t seem to work.
typedef bit[3:0] warp_id_t;
module test;
int in_use[warp_id_t];
int index_q[$];
in_use[4'd10] = 1;
in_use[4'd15] = 1;
in_use[4'd1] = 1;
in_use[4'd5] = 1;
in_use[4'd4] = 1;
in_use[4'd7] = 1;
foreach(in_use[i]) begin
$display("in_use[%0d]: %0d",i,in_use[i]);
index_q = in_use.unique();
$display("size of index_q : %0d", index_q.size());
foreach (index_q[i]) begin
$display("Listing elements in index_q[%0d] : %0d",i,index_q[i]);
//index_q.shuffle();
//for ( int j = 0; j < index_q.size; j++ ) begin
// $display("after shuffle, index element: %0d",index_q[j]);
//end
Is there any other way of finding the indices other than pushing the indices into another queue by iterating the array.
Madhu
In reply to mseyunni:
It’s difficult to know what you are trying to accomplish. When you say " to list all the indices of an associative array". Do you mean you want to print a list, or do you want to construct an array containing all the indices
$display("%0d",i);
index_q = in_use.find_index with (1);
I want to capture the indices into a queue to use one of them (randomly picked) as the id that I want to use in my transaction. find_index with (1) works. However, I had to declare index_q is of type warp_id_t. Does the returned queue should be of type index, right ?
Also, how does find_index with (1) works internally ? ( I see this is something similar to while(1)), but I want to understand the internal working of the search.
Madhu
That’s how I do it.
There is, to my knowledge, no function such as ‘keys’.
Ray
Yes the returned queue has an element type that matches the associative array index type.
All of the builtin find_ methods require a with (expression). Please see section 7.12.1 Array locator methods in the IEEE 1800-2012 LRM.
In reply to raysalemi:
for some reason .unique, doesn’t seem to work in my original post. Not sure, what was the issue ?
Madhu
What does “doesn’t seem to work” mean?
Doesn’t compile - what is the error?
Doesn’t give the the result’s you are expecting. What did you expect? and what did you get?
I get compile error, if I declare
warp_id_t index_q[$];
Incompatible complex type assignment
Type of source expression is incompatible with type of target expression.
Mismatching types cannot be used in assignments, initializations and
instantiations. The type of the target is 'bit[3:0]$[$]', while the type of
the source is 'int$[$]'.
Source Expression: in_use.unique
on the other hand, if i change the declaration to,
int index_q[$];
I get a different result than what is expected,
size of index_q : 1
Listing elements in index_q[0] : 1
Now, what I don’t understand the reason for the compile error as returned indices is of type warp_id_t, and it does work with your earlier proposed solution of find_index with (1).
after changing the type to int, the result doesn’t make sense.
can you please explain ?
I believe you should be using unique_index(), not unique().
No. Still the same error even with unique_index(). In fact, the LRM has unique(), but unique_index() didn’t give any compile error though !!!
