I have tried with keeping the delays in all run_phases of my components,still it is coming out in 0 time and i have tried with same succesor for two phases i.e for run_phase and post_shutdown_phase keeping extract_phase as succesor(it is suggested in source code) still i find the same issue.
You should never have an absolute time in your run_phases.
UVM requires the usage of the objection mechanism. If you do not it stops immediately at time 0.
