zz8318
December 21, 2018, 1:58am
1
/proj/common/my_common_pkg.sv
package my_common_pkg;
import uvm_pkg::*;
`include "my_globals.svh"
endpackage: my_common_pkg
/proj/common/my_globals.svh
typedef struct {
string name;
uint32 addr;
} reg_t;
reg_t reg_arr[$];
import "DPI-C" context function void get_all_reg();
export "DPI-C" function exported_sv_function;
function void exported_sv_function(input reg_t ele);
reg_arr.push_back(ele);
endfunction : exported_sv_function
and here is my c file: (proj/common/get_all_reg.cpp)
[c]
struct reg_t{
const char* name;
uint32 addr;
extern “C” {
void exported_sv_function(reg_t);
void get_all_reg() {
reg_t reg_element;
… // get infomation
exported_sv_function(reg_element);
} // extern “C”
[/c]
/proj/test/my_test_pkg.sv
package my_test_pkg;
import uvm_pkg::*;
import my_common_pkg::*;
`include "my_test1.svh"
endpackage : my_test_pkg
and then in my test file (/proj/test/my_test1.svh), I will invoke the get_all_reg() function as shown below.
class my_test1 extends uvm_test;
super.run_phase(phase);
phase.raise_objection(this, "raise objection");
get_all_reg();
But in the runtime, it will report below error:
Error-[DPI-DXFNF] DPI export function not found
The DPI export function/task ‘exported_sv_function’ called from a user/external C/C++/DPI-C code originated from import DPI function is not defined or visible.
dave_59
December 21, 2018, 6:05am
2
In reply to zz8318 :
It would help to show a minimal, complete example . Where are the DPI import/export statements in relation to where the call to get_all_reg()?
zz8318
December 29, 2018, 12:24am
3
In reply to dave_59 :
I edited my post. Thanks for your advice.
Merry X-mas and Happy new year.
dave_59
December 29, 2018, 3:18am
4
That’s better, but certainly not minimal or complete. This worked for me:
typedef struct {
string name;
int addr;
} reg_t;
reg_t reg_arr[$];
class A;
task run;
get_all_reg;
import my_test_pkg::*;
A h=new;
initial h.run;
Note the changes I had to make get the C++ code to compile
extern "C" {
void exported_sv_function(const reg_t*);
reg_t reg_element;
// get infomation
exported_SystemVerilog_function(®_element);
} // extern "C"
zz8318
December 29, 2018, 4:00pm
5
The run task in your code is invoked in the top module. Shall I know the reason ?
dave_59
December 29, 2018, 4:12pm
6
I’m giving you a minimal complete example that you can try yourself. You need to do the same, otherwise no one can help you.
zz8318
December 29, 2018, 4:24pm
7
I was not able to solve this problem in my side. And I tried another way to implement it but failed at below error. I am not sure if I use the dpi correctly or not. Could you please take a look ?
I don’t use ‘export’ function and what I tried is shown below.
/proj/common/my_globals.svh:
typedef struct {
string name;
uint32 addr;
} reg_t;
import "DPI-C" context function void get_all_reg2(output reg_t arr[]);
[c]
struct reg_t{
const char* name;
uint32 addr;
extern “C” {
void get_all_reg2(svOpenArrayHandle arr) {
reg_t reg_element;
reg_t *reg_array;
reg_array = (reg_t*)svGetArrayPtr(arr);
while(...) {
reg_array[idx] = reg_element;
idx++;
} // extern “C”
[/c]
and then in my test file (/proj/test/my_test2.svh), I will invoke the get_all_reg2() function as shown below.
class my_test2 extends uvm_test;
reg_t m_reg_array[1024]; // shall we need to identify 1024 ?
get_all_reg2(m_reg_array);
and I met the segmentation fault…
cgales
December 29, 2018, 4:41pm
8
Please read carefully what Dave mentioned regarding posting a minimal complete example. It needs to be an complete set of code that will compile for both SV and C++. Posting incomplete code sections with ‘while(…)’ and ‘…’ DOES NOT HELP since they can’t be compiled to determine what the issue is.
Dave posted a complete example that works. Please post a complete example which exhibits the issue you are seeing.
zz8318
December 29, 2018, 5:04pm
9
In reply to cgales :
Thanks for your advice. I will take a further investigate and try to figure it out.
