How to execute a recursive factory override?
I’m trying to execute a simple UVM factory example.
When I try a recursive override, I got the error message
UVM_ERROR @ 0: reporter [OVRDLOOP] Recursive loop detected while finding override.
If I want to execute a factory overriding in recursive factory override. What am I supposed to do?
   set_type_override_by_type(base_agent::get_type(), child_agent::get_type());
   set_type_override_by_type(child_agent::get_type(), base_agent::get_type());
In reply to UVM_LOVE:
Not sure I understand what you are trying to accomplish. Are you trying to undo the factory override and revert back to the base_agent?
Don’t register the 1st override in that case ( based on configuration / run-time switch )
You won’t need to override a previous override that way.
