I’m trying to understand uvm phase process. Especially, we can implement forever statment such as the below example.
class my_monitor extends uvm_monitor;
`uvm_component_utils (my_monitor)
function new (string name, uvm_component parent)
super.new (name, parent);
virtual function void build_phase (uvm_phase phase)
super.build_phase (phase);
virtual task run_phase (uvm_phase phase);
forever begin
data_obj.data = vif.data;
data_obj.addr = vif.addr;
if (enable_coverage)
data_obj.cg_trans.sample();
// Send data object through the analysis
mon_analysis_port.write (data_obj);
As you can see the above, there is implemented with foreever statement.
I’m wonder that if we use forever statment, who/how does kill it?
In UVM Monitor - Verification Guide , some article answered by “don’t use forever statments”.
Even if I implement a raise/drop objection in run_phase, doesn’t forever stop?
The advice “don’t use forever statements” is incorrect. All run_phase tasks in all components get killed when the last objection drops. You would not put a raise/drop objection around a forever loop like those used in a monitor or driver unless there was some condition to break out of the forever loop.
Hi in case of response handler Sequance (responder Sequance) which needs to have under forever loop. what do you suggest to achieve end of simulation independent of this Sequance completion.??
