I’m now use the questasim/10.2 to do the simulation and use the follow line to dummp fsdb format waveform,but it with two issue,
can you help me on it? thank you very much!
$fsdbDumpfile("./my_design.fsdb");
$fsdbDumpvars(0, tb)
but it with below two issue:
1.fsdp dump report a Error:
Novas Create FSDB file ‘.my_design.fsdb’
Novas Begin traversing the scope(tb), layer(0).
Novas Warning: Unknown scope type: tb.my_design…wchannel_fifo.WRITE_INTO_FIFO[7] 722
** Error: (vsim-PLI-3486) acc_fetch_defname(): The object_handle parameter is not a handle to a module, primitive, or architecture instance. : ../tb/sv/tb.sv(3039)
Time: 0 ps Iteration: 0 Instance: /tb
RTL code of tb.my_design…wchannel_fifo.WRITE_INTO_FIFO
generate
genvar i;
for(i=0; i<FIFO_DEPTH; i=i+1) begin : WRITE_INTO_FIFO
endgenerate
- the fsdb file and not get multi-dimensional array signals
