Could any one please help me in writing the verification code for yapp packet router.I don’t have any experience in verification field.i’m a fresher.
I am creating yapp uvc.
I have a packet class when i am driving the packet to dut its not getting any value from driver.iam unable to find my mistake could any one please help me.
this is my packet class : i declared short_yapp_packet class as my packet class in test class.
typedef enum{BAD_PARITY,GOOD_PARITY}parity_t;
class yapp_packet extends uvm_sequence_item;
rand bit [5:0]length;
rand bit [1:0]addr;
rand bit [7:0]payload[];
bit [7:0]parity;
rand int packet_delay;
rand parity_t parity_type;
`uvm_object_utils_begin(yapp_packet)
`uvm_field_int(length,UVM_DEFAULT)
`uvm_field_int(addr,UVM_DEFAULT)
`uvm_field_array_int(payload,UVM_DEFAULT)
`uvm_field_int(parity,UVM_DEFAULT)
`uvm_field_int(packet_delay,UVM_DEFAULT)
`uvm_field_enum(parity_t,parity_type,UVM_DEFAULT)
`uvm_object_utils_end
//constructor
function bit[7:0]calc_parity();
calc_parity={length,addr};
for(int i=0;i<length;i++)
calc_parity =calc_parity^payload.xor();
if(parity_type==GOOD_PARITY)
parity=calc_parity();
parity=~parity;
constraint valid_address{addr>=0;addr<3;}
constraint packet_length{length>0;length<64;}
constraint pck_size{length==payload.size();}
constraint pck_delay{packet_delay>0;packet_delay<=20;}
class short_yapp_packet extends yapp_packet;
`uvm_object_utils(short_yapp_packet)
//constructor
constraint packet_length{length<15;}
constraint valid_address{addr>=0; addr<2;}
sequence: in sequence class i am driving 3 packets to 3 different addresses (i was taken default sequence is yapp_012_seq in test class)
class yapp_sequence extends uvm_sequence#(yapp_packet);
`uvm_object_utils(yapp_sequence)
//constructor
virtual task body();
`uvm_info(get_type_name(),"starting of randomization",UVM_HIGH);
repeat(5)
`uvm_do(req)
class yapp_012_seq extends yapp_sequence;
`uvm_object_utils(yapp_012_seq)
//constructor
`uvm_info(get_type_name(),"starting of randomization to send 3 packets to 3 address locations",UVM_HIGH)
`uvm_do_with(req, {addr == 0;})
`uvm_do_with(req, {addr == 1;})
`uvm_do_with(req, {addr == 2;})
driver :
class yapp_driver extends uvm_driver#(yapp_packet);
//virtual interface declaration
//yapp_packet handle
`uvm_component_utils_begin(yapp_driver)
`uvm_field_object(req, UVM_ALL_ON)
`uvm_component_utils_end
//new() constructor
//build_phase
if(!yapp_vif_config::get(this,"","vif",vif))
`uvm_fatal("NOVIF",{"No virtual interface set for:",get_full_name(),".vif"})
super.build_phase(phase);
//reset_phase
virtual task reset_phase(uvm_phase phase);
@(posedge vif.rst);
`uvm_info(get_type_name(),"Reset OBSERVED",UVM_MEDIUM)
vif.in_data<=8'hz;
vif.in_data_vld<='z;
virtual task send_to_dut(yapp_packet packet);
fork forever
vif.drv.in_data_vld <=1'b1;
@(negedge vif.clk iff((!vif.drv.in_suspend)&&(vif.drv.in_data_vld)));
`uvm_info(get_type_name(),$sformatf("sending the packet length :%d \t addr :%d \t payload : %h ",packet.length,packet.addr,packet.payload),UVM_MEDIUM)
vif.drv.in_data<={packet.length,packet.addr};
for(int i=0;i<packet.length;i++)
vif.drv.in_data<=packet.payload[i];
vif.in_data_vld <=1'b0;
@(negedge vif.clk iff((!vif.drv.in_suspend)&&(!vif.drv.in_data_vld)));
`uvm_info(get_type_name(),$sformatf("sending the packet parity :%d",packet.parity),UVM_MEDIUM)
vif.drv.in_data <=packet.parity;
@(vif.drv)
repeat(packet.packet_delay);
repeat(2)@(vif.drv);
join
virtual task main_phase(uvm_phase phase);
forever
@(vif.drv);
send_to_dut(req);
seq_item_port.item_done();
virtual function void start_of_simulation_phase(uvm_phase phase);
`uvm_info(get_type_name(),"driver start_of_simulation_phase",UVM_HIGH)
