How to drive output clockvar which is a net?
Consider the following clocking block definition ::
 logic [1:0] a ;
 logic [2:0] out;
 wire  [1:0] b ;
 clocking  cb @( posedge clk );
    default input  #1step  output #2 ;
    output  a  , b ;
     input  out ;
 endclocking
Typically if user wants to drive output clockvar ’ a ’ which is actually a variable we use :
  //  Within  any  procedural  block
      @( cb );
      cb.a <= 2 ;
To drive clockvar ’ b ’ which is a net ( so I can’t drive procedurally ) , I would be using :assign cb.b = …
Typically we wait for clocking block event @( cb ) before driving output clockvars ,
how could I incorporate @( cb ) with assign statement to drive output clockvar b ?
The other question is how could I drive output clockvar b at the same time as I am driving clockvar a i.e How do I synchronize the two drives ?
In reply to Have_A_Doubt:
Clocking block output variables are always written using procedural drive statements—it does not matter if the target signal is a variable or a net. You cannot write to a clocking block output variable with any other kind of assignment.
