I am looking for way to disable assert in side uvm component for certain test. Bellow simple code represent my env, with comment for requirement. I thought i can use $assertoff. I can modify uvm component if required additional instrumentation to achieve this. Thanks,
import uvm_pkg::*;
`include "uvm_macros.svh"
class tb_env extends uvm_component;
`uvm_component_utils(tb_env)
int exp_val = 0;
int act_val = 0;
function new(string name = "tb_env", uvm_component parent = null);
super.new(name, parent);
virtual task run_phase (uvm_phase phase);
super.run_phase(phase);
phase.raise_objection(this);
#10us;
ASRT: assert ( exp_val == act_val) else
`uvm_error(get_name(), "Error");
#10us;
`uvm_info(get_name(), "Done env", UVM_LOW);
phase.drop_objection(this);
endtask : run_phase
program tb_run;
initial
tb_env env = new("env");
// Requirement: Disable assertion env.ASRT with system call $assertoff(...)
run_test();
#5us;
env.exp_val = 1;
join
endprogram
