Assume that there is an array of 4 bit size eg: c[3:0] and every time one bit should be 1 and remaining bits should be 0’s and it should display number of 1’s in that array.
In reply to dinakarkuchi9:
You can the the system functions in SystemVerilog anywhere, in SAV, procedural blocks, constraints:
- $onehot(expression) returns `true (bit 1’b1) if only one bit of the expression is high.
- $onehot0(expression) returns `true (bit 1’b1) if at most one bit of the expression is high. This is equivalent to $onehot(expression) || expression==0
- $isunknown(expression) returns `true (bit 1’b1) if any bit of the expression is X or Z. This is equivalent to ^(expression) === ’bx.
- $countones (expression) returns the number of ONEs in a bit vector expression. X and Z values are not counted towards the number of ones.
- $countbits(expression, list_of_control_bits) // list used to identifies which values to count list_of_control_bits ::= control_bit { , control_bit } $countbits returns (as an int)the number of bits that have a specific set of values (e.g., 0, 1, X, Z) in a bit vector. For example, [1] $countbits (expression, '1, '0) returns the number of bits in expression having values 1or 0. $countbits (expression, 'x, 'z) returns the number of bits in expression having values X. or Z.
- SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
- SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy - SVA: Package for dynamic and range delays and repeats | Verification Academy
- SVA in a UVM Class-based Environment
