Whether we can declare a Array in typedef struct,I want to declare Payload array in typedef, array size changes according to type/length.
How to declare payload array in Typedef struct.
In reply to shiva kumar:
How does your payload array look like?
Is it a good approach to use a struct. If you are working with UVM a seq_item (transaction) might be the prefered construct.
I am using Axi streaming operators to unpack data from queue.(I already packed completed ethernet packet data from interface to queue).By using typedef(by declaring Ethernet MAC fields) i have to unpack from queue.
This might help:
https://verificationacademy.com/cookbook/transaction/methods#do_pack_and_do_unpack
can we directly tap data from interface by using Axi streaming operators
like this {>>{a, b, c, d}} = value;
Did you try it?
It should work. SV allows a concatenation on the LHS.
I want to declare payload as array in typedef,then i want to use streaming operatoe to drive data into it.
is it possible to declare array in typedef
In a typedef you can use any SV/Verilog or customized data type.
How to declare dynamic array in typedef
There is nothing magic but simply straight forward.
See the code example here:
typedef struct {
int a;
bit b;
string da [];
} struct_t;
struct_t x;
x.a = 12;
x.b = 1'b1;
x.da = new[10];
x.da[0] = "max";
x.da[1] = "min";
$display("da has %0d entries", x.da.size());
for (int i = 0; i <= x.da.size(); i++)
$display("x.da[%0d] = %s", i, x.da[i]);
