How to deal with hdl_path with escape identifier
hi:
I encountered a problem where the path of a certain signal contains \ due to dft. I tried the following approaches, but none of them worked.
1: assign vif.xx = tb_top.dut.U_ap_top.\g_core[0].xx
2: assign vif.xx = tb_top.dut.U_ap_top.\\g_core[0].xx
In reply to jianfeng.he:
What does ‘none of them worked’ mean? Did you get a syntax error? Did it compile and not give the results you are expecting?
Verilog escaped identifiers require a white space character to terminate. Neither the leading backslash, nor the whitespace are considered part of the identifier. Without seeing your complete example, but I’m guessing this would work:
assign vif.xx = tb_top.dut.U_ap_top.\\g_core[0] .xx
(Note the space)
In reply to cgales:
Reported an error similar to “path not found”.
In reply to Mark Curry:
(Note the space)
Thank you for your help, this works well
