i want to make my Test parametrised , so Thats why i need to make it parametrised can you please what is the syntax of creating a parametrised class using UVM create method
In reply to nimmy_248:
- When you create class. You should register your component with `uvm_component_param_utils:
Example:
`uvm_component_param_utils(your_component_class#(your_param))
- Declare your class and create:
your_component_class#(your_param) comp;
// Create it
comp = your_component_class#(your_param)::type_id::create("string", this);
Or use typedef for easy to read.
