Hi
I need some help with the following issue I have learning the uvm flow. In the environment a uart is under test. I’ve written a monitor for catching DUT transmit packets. The uart allows programming for the number of data bits, number of stop bits, parity enable and baud rate so before transmitting data the monitor needs to be configured. This is where I am stuck. If I use a fixed configuration then the monitor correctly gets the data and scoreboard checks on the packet work. However when the configuration is randomized then the monitor has no idea of the new configuration so cannot correctly decode the transmit packet. This randomization is done in a virtual sequencer if that’s significant.
Below is my test topology. In m_uart_tx_agent.m_monitor there is a function named config() that I wish to access. In uart_ctrl_tx_poll_test I can call the function with m_env.m_uart_tx_agent.m_monitor.config() and this works. As mentioned item randomization is done in the sequence not in the test. From the virtual sequencer I’ve been unable to access the function. I appreciate that using dot hierarchy is not recommended with uvm for reuse but it’s all that I can get working at the moment. Any advice or examples on this issue would be greatly appreciated.
Name Type Size Value
uvm_test_top uart_ctrl_tx_poll_test - @470
m_env uart_ctrl_env - @569
apb2reg_predictor uvm_component - @588
bus_in uvm_analysis_imp - @595
reg_ap uvm_analysis_port - @603
m_apb_agent apb_agent - @581
m_driver apb_driver - @653
m_monitor apb_monitor - @646
m_sequencer apb_sequencer - @676
m_reg_func_cov_monitor uart_ctrl_reg_functional_coverage - @622
analysis_imp uvm_analysis_imp - @629
m_scoreboard uart_ctrl_scoreboard - @637
apb uvm_tlm_analysis_fifo #(T) - @801
m_uart_tx_agent uart_transmit_agent - @615
m_monitor uart_transmit_monitor - @849
Andrew
