Hi,
If your requirement is to disable perticular assertion for any specific testcase then you can use “disable iff” feature of assertion
Ways to use it
- disable on perticular signal (either DUT/ generate as per your requirment)
- disable on bit which you can take it from run time option($value$plusargs/$test$plusargs)
Hope it will help you.
Regards,
Vinay Jain
