How to bind parameterized module
In reply to Yoram-Stern:
Hi.
I have a parameterized design module that a colleague wrote,
and I have an assertions module (also parameterized) that I want to instance into his code - without modifying it (i.e. using systemverilog bind).
How can I do the bind of the parameters?
Thanks,
The syntax for the bind is:
syntax for the bind construct is as follows:
bind_directive4 ::=
bind bind_target_scope [: bind_target_instance_list] bind_instantiation ;
| bind bind_target_instance bind_instantiation ;
bind_target_scope ::=
    module_identifier
 | interface_identifier
bind_target_instance ::=
    hierarchical_identifier constant_bit_select
bind_target_instance_list ::=
   bind_target_instance { , bind_target_instance }
bind_instantiation ::=
     program_instantiation
   | module_instantiation
   | interface_instantiation
   | checker_instantiation
Below is a complete example from my SVA book.
module counter (output logic[2:0] count_out, // counter output
                input  logic[2:0] data_in, // data to load
                input  logic ld_enb, count_enb, rst_n, clk);
    logic [2:0]  count;
    logic                      tc;
    assign count_out                   =count;
    assign tc                          = count==3'b111;
    default clocking @(negedge clk); endclocking
    always @ (posedge clk or negedge rst_n)
        if (!rst_n)         count <= 0;
        else if (ld_enb)    count <= data_in;
        else if (count_enb) count <= count_out + 1;
endmodule // counter
module counter_props (
  input logic[2:0] count_out,  //  counter output
  input  logic ld_enb, rst_n,
  input  logic [2:0] count,        // internal design signal
  input  logic tc,                  // internal design signal
  input  logic clk
   property p_tc;
    disable iff (!rst_n)
         (count)==3'b111 |-> tc;
   endproperty : p_tc
   ap_tc : assert property(@ (posedge clk) p_tc) else
     $display ("0t error in terminal count", $time);
   ap_counter : assert property( @ (posedge clk) tc |-> ##8 tc);
 endmodule : counter_props
module counter_tb;
  timeunit 1ns;   timeprecision 1ns;
    logic  ld_enb=0;
    logic [2:0]  data_in;
    wire  [2:0]  count_out;
    logic  count_enb=0;
    logic  clk=0;
    logic  rst_n=1;
    initial forever #10 clk=!clk;
  counter
   DUT  (
       .ld_enb (ld_enb ) ,
      .data_in (data_in ) ,
      .count_out (count_out ) ,
      .count_enb (count_enb ) ,
      .clk (clk ) ,
      .rst_n (rst_n ) );
  bind counter counter_props counter_props_1(
          .count_out(count),
          .ld_enb(ld_enb),
          .rst_n(rst_n),
          .count(count),
          .clk(clk),
          .tc(tc));
        ##1;
	data_in   <= 8'hF0;
	ld_enb 	  <= 1;
	count_enb <= 1'b1;
	##1;
	ld_enb <= 1'b0;
endmodule : counter_tb
  • SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
