Hi Verification Academy Forum Desk,
As per the subject I’ve the following query. In my test I’m passing 2 different sequences, emif_sequence and image_sequence. emif_sequence is for configuring my system which is to be done first by the emif_driver and I’m doing it. After that the image_driver should start sending packet after getting the enable signal from the emif. But though the emif_driver is acting properly, but my image_driver is getting activated before the time, so I’m losing packet at the receiver side, because during that time receiver hasn’t receive the enable signal from the emif. So please tell me how to delay the operation of image_driver or how to add delay between two UVM phases, as my emif is running in pre_main_phase and image is inmain_phase. Following is my code sample.
class my_project_verif_test_4k_x_nk extends my_project_verif_test_base;
my_project_verif_env env;
my_project_verif_log log;
bit is_timeout = 1'b0;
my_project_verif_env_cfg_ddr3_ctrl_mon_test env_cfg;
`uvm_component_utils(my_project_verif_test_4k_x_nk)
function new(string name = "my_project_verif_test_4k_x_nk",uvm_component parent=null);
super.new(name,parent);
log = new("NETRA_4K_X_nK_TEST");
`spark_verif_note(log,"Inside constructor");
endfunction : new
super.build_phase(phase);
//Override Configuration
env_cfg = new("test_env_cfg");
uvm_config_db#(my_project_verif_env_config)::set(this,"*","env_cfg",this.env_cfg);
// Set default sequence
uvm_config_db #(uvm_object_wrapper)::set(this,"*.emif_gen.pre_main_phase",
"default_sequence",
my_project_verif_emif_std_sequence::type_id::get());
uvm_config_db#(uvm_object_wrapper)::set(this,"*.image_gen.main_phase",
"default_sequence",
my_project_verif_image_4k_x_3k_seq::type_id::get());
endfunction : build_phase
endclass : my_project_verif_test_4k_x_nk
