Hi Forum.,
- How Coverpoint will keep a track of variable to be covered.i.e.,
When the covergroup sample function is called ,from that point of time to till the end of the test will the coverpoint variable be tracked ,or only at the point of time when sample() method is called it works. - Because for any coverpoint variable if it is said it as a hit of 9 or 10 means, that varaible as to be exercised or used 9 or 10 times. But when we call sample() method only once, how it will know the coverpoint variable is hitted 9 or 10 times.
Any suggestion are appreciated.
Thanks in Advance.
