I am writing some behavioral model (example is shown below).
How should asynchronous reset be modeled?
interface some_if(input clk1, input clk2);
bit[7:0] data;
bit rst1;
clocking cb_clk1 @(posedge clk1);
default input #1step output #2ns;
input i_data = data;
output o_data = data;
endclocking
clocking cb_clk2 @(posedge clk2);
input i_rst1 = rst1;
output o_rst1 = rst1;
endclocking
class t_some_if extends t_base_some_if;
task wait_for_clk1;
@cb_clk1;
function bit[7:0] get_data();
return cb_clk1.i_data;
task set_data(bit[7:0] data);
cb_clk1.o_data = data;
task wait_for_clk2;
@cb_clk2;
function bit get_rst1();
return cb_clk2.i_rst1;
task set_rst1(bit rst1);
cb_clk2.o_rst1 = rst1;
endinterface
class some_module1;
t_base_some_if m_some_if;
task run1();
forever begin
m_some_if.wait_for_clk1(); //here I want clear data on asynchronous reset
m_some_if.set_data(data);
class some_module2;
task run2();
forever begin
m_some_if.wait_for_clk2();
m_some_if.set_rst1(1);
m_some_if.set_rst1(0);
I think, asynchronous reset could be modeled using fork… join_any (example shown below).
bit rst1;
task wait_for_rst1;
@(negedge rst1);
endinterface
class some_module1;
task run1();
forever begin
m_some_if.wait_for_rst1();
join_any
disable fork;
if(m_some_if.get_rst1() == 0) begin
m_some_if.set_data('0);
else begin
Also I think asynchronous reset could be modeled using mailbox.
What way do you recommend?
