How "ref" keyword used while passing class object as argument function
Hi ,
Could anyone explain, how the “ref” is useful/difference in following cases (case 1 and case 2)
class B;
int a;
int b;
class A;
int x ;
int y ;
function B fun ( B obj ); // case 1
function B fun ( ref B obj ); // case 2
// some code
return obj;
A obj_a ;
B obj_b ;
initial
obj_a = new();
obj_b = new();
obj_b = fun (obj_b);
Balu
In reply to kbkdec15:
The ref keyword is not needed because obj is already a class variable that has a handle that references a class object. You almost never need the ref keyword with function arguments except as an optimization when you have large aggregate data types as arguments. If you only need to access a few elements of an array, a ref argument saves you having to copy in or out all of the elements. \
For a task, you may want to read: const ref | Verification Academy
Thank you Dave.
I understood about the “ref” usage.
-Balu
