I have tried a apb slave, can there be a apb master or a apb slave right? is it possible for a same bus to act as master and slave at different instance, so should i need to write a apb_master dut separately and apb_slave dut separately? . please clarify me as i am new to building interfaces. can anyone give me a perfect example to connect how transfers happen between a apb master and slave?
module apb_slave
addrWidth = 8,
dataWidth = 32
input clk,
input rst_n,
input [addrWidth-1:0] paddr,
input pwrite,
input psel,
input penable,
input [dataWidth-1:0] pwdata,
output logic [dataWidth-1:0] prdata
logic [dataWidth-1:0] mem [256];
logic [1:0] apb_st;
const logic [1:0] SETUP = 0;
const logic [1:0] W_ENABLE = 1;
const logic [1:0] R_ENABLE = 2;
// SETUP → ENABLE
always @(negedge rst_n or posedge clk) begin
if (rst_n == 0) begin
apb_st <= 0;
prdata <= 0;
else begin
case (apb_st)
SETUP : begin
// clear the prdata
prdata <= 0;
// Move to ENABLE when the psel is asserted
if (psel && !penable) begin
if (pwrite) begin
apb_st <= W_ENABLE;
else begin
apb_st <= R_ENABLE;
W_ENABLE : begin
// write pwdata to memory
if (psel && penable && pwrite) begin
mem[paddr] <= pwdata;
// return to SETUP
apb_st <= SETUP;
R_ENABLE : begin
// read prdata from memory
if (psel && penable && !pwrite) begin
prdata <= mem[paddr];
// return to SETUP
apb_st <= SETUP;
endcase
initial
$dumpfile(“test.vcd”);
$dumpvars;
