When I was learning SystemVerilog Scheduling, I don’t understand some part of the scheduling chart. I saw for each region from active to re-inactive, there is a path to loop back. I don’t understand how Observed region can trigger a loop back to Active region. I believe no actions in the observed region can change any signal value, even the initialization is only changing the local variable within the property.
I described the SystemVerilog scheduling events in my SVA book. Below is a link to that page
Thanks Ben, I agree with you because I also think the Observed region shouldn’t have loop back. But do you know why there is this loop back in the IEEE standard 1800-2005? Is it because that they just want to leave a hook which could be used once needed for future systemverilog standard?
consider the following example:
With ap: assert property($rose(a) |-> 1) flip(e);
“e” changes in the Reactive Region.
From the Reactive Region you loop back to the Active Region when you recalculate
assign b= e; // if (e) changes
There is no reassignment in the NBA. When “e” changes in the 2nd loop through the Active, the always_ff @(posedge clk) d <= e; does not get reassigned.
I am really part of SV-AC (assertion committee); there is another committee that address those other timing and language issues. But I do see a need to loop back.
module top;
bit clk, a;
logic b,c, d, e=1;
initial forever #10 clk=!clk;
always_ff @(posedge clk) begin
d <= e;
assign b= e;
function void flip(logic w);
e = !w;
repeat(200) begin
@(posedge clk);
if (!randomize(a) with
{ a dist {1'b1:=1, 1'b0:=2};
$stop;
I understand that there should be a loop back from reactive region, but I was talking about the loop from Observed region. In the related section of your book there is no such a loop from Observed region, but it does exist in the IEEE standard.
