I have a scenario where I want to override specific instance of base class with it’s extended class.
code for class and hierarchy :
class basechain extends uvm_component;
`uvm_component_utils(basechain)
function new(string name = "basechain", uvm_component parent = null);
  super.new(name, parent);
// Constructor function
function initialize_setup (int size = 1);
      /* Some variables initialization here*/
class extentedclass1 extends basechain;
`uvm_component_utils(extentedclass1)
function new(string name = "extentedclass1", uvm_component parent = null);
      super.initialize_setup(1);
class extentedclass2 extends extentedclass1;
basechain DUTTop;
basechain DUTBot;
`uvm_component_utils(extentedclass2)
function new(string name = "extentedclass2", uvm_component parent = null);
function initialize_setup ();
      // Since we integrate other chains, set ours to 1
      super.initialize_setup(20);
      DUTTop = basechain::type_id::create("DUTTop",this);
      DUTTop.initialize_setup(2);
      DUTBot = basechain::type_id::create("DUTBot",this);
      DUTBot.initialize_setup(3);
class dut_scanchains extends uvm_component;
`uvm_component_utils(dut_scanchains)
function new(string name = "dut_scanchains", uvm_component parent = null);
basechain integexp;
task scanchain_setup(dut_scanchain_type scanchain_type);
         integexp=basechain::type_id::create("integexp",this);
         integexp.initialize_setup();
scanchain_setup function is called in build phase of one the class
Working Topology:
Name                         Type                        Size  Value
uvm_test_top                 dut_level0_integchain       -     @344
  m_env                      dut_env                     -     @375
    m_agent                  dut_agent                   -     @773
      m_driver               dut_driver                  -     @792
        bdbfm                dut_bd_bfm                  -     @990
        bfm                  dut_bfm                     -     @981
        rsp_port             uvm_analysis_port           -     @811
        seq_item_port        uvm_seq_item_pull_port      -     @801
        tbbfm                dut_tb_bfm                  -     @999
      m_monitor              dut_monitor                 -     @958
        item_collected_port  uvm_analysis_port           -     @967
      m_sequencer            dut_sequencer               -     @821
        rsp_export           uvm_analysis_export         -     @830
        seq_item_export      uvm_seq_item_pull_imp       -     @948
        arbitration_queue    array                       0     -
        lock_queue           array                       0     -
        num_last_reqs        integral                    32    'd1
        num_last_rsps        integral                    32    'd1
    m_scoreboard             dut_scoreboard              -     @782
      packets_collected      uvm_tlm_analysis_fifo #(T)  -     @1017
        analysis_export      uvm_analysis_imp            -     @1066
        get_ap               uvm_analysis_port           -     @1056
        get_peek_export      uvm_get_peek_imp            -     @1036
        put_ap               uvm_analysis_port           -     @1046
        put_export           uvm_put_imp                 -     @1026
      dut_checker            dut_chk                     -     @1080
  m_dutscanchains            dut_scanchains              -     @362
    integexp                 extentedclass2              -     @399
      Block0                 basechain                   -     @606
      DUTBot                 basechain                   -     @597
      DUTTop                 basechain                   -     @588
Now I make the following changes:
extentedclass2 integexp;
to
basechain integexp;
basechain is the parent. I wish to override this basechain instance with specific extentedclass2 type based my test requirement. I used
set_inst_override_by_type("m_allchains.integexp",basechain::get_type(), extentedclass2::get_type());
Instance overriding seem to be successful but I don’t see sub instance appearing. subchains of base class and other instances are missing (compare the working topology and non-working topology)
Example failing topology :
    m_agent                  dut_agent                   -     @413
      m_driver               dut_driver                  -     @432
        bdbfm                dut_bd_bfm                  -     @630
        bfm                  dut_bfm                     -     @621
        rsp_port             uvm_analysis_port           -     @451
        seq_item_port        uvm_seq_item_pull_port      -     @441
        tbbfm                dut_tb_bfm                  -     @639
      m_monitor              dut_monitor                 -     @598
        item_collected_port  uvm_analysis_port           -     @607
      m_sequencer            dut_sequencer               -     @461
        rsp_export           uvm_analysis_export         -     @470
        seq_item_export      uvm_seq_item_pull_imp       -     @588
    m_scoreboard             dut_scoreboard              -     @422
      packets_collected      uvm_tlm_analysis_fifo #(T)  -     @657
        analysis_export      uvm_analysis_imp            -     @706
        get_ap               uvm_analysis_port           -     @696
        get_peek_export      uvm_get_peek_imp            -     @676
        put_ap               uvm_analysis_port           -     @686
        put_export           uvm_put_imp                 -     @666
      dut_checker            dut_chk                     -     @720
Clearly underlying instances are missing and They are not being instantiated. What am I doing wrong ?
