Hi
I have a transaction class extending from ovm_sequence_item:
class my_trans extends ovm_sequence_item;
// Class members
rand bit first;
rand int info;
rand int delay;
rand byte wdata[];
`ovm_object_utils_begin(my_trans)
`ovm_field_int (first, OVM_ALL_ON)
`ovm_field_array_int(wdata, OVM_ALL_ON)
`ovm_object_utils_end
//Methods
function new(string name= "...");
function string convert2string();
string str1;
str1 = {
$sformatf("m_first :'h%h\n", first),
$sformatf("wdata :%x\n", wdata),
return(str1);
I use this function in my scoreboard when comparing two transactions, for debug purposes by calling txn.conver2string()
I get a compile time error saying illegal format specifier. Can someone help me understand how can I convert this dynamic array to string format and print it?
If you want your entire array on a single line, you can write
string str1;
str1 = {
$swriteh(str, "%s wdata :%0p\n", str, wdata),
return(str1);
Otherwise you will need to use a foreach or for loop to iterate over each element and insert newlines where you want them.
Hi All,
I have a dynamic array on data.
To change dynamic array to string variable for my debugging process.
bit data[]; //Declaration
string data2string= "";
data = new[primitive]; // primitive will be change dynamically
data2string = convert2string();
string str1;
str1 = {
$sformatf("data:'h%h\n",data),
return(str1);
But i am facing a compilation issue.
Rajaraman
In reply to Rajaraman Rak7:
I can think of two choices:
You can use the streaming operator to pack data into a fixed sized variable
bit [MAX_DATA_SIZE-1:0] data_packed;
data_packed = {>>{data}};
str1 = $sformatf("data:'h%h\n",data_packed);
You might have to play around with the packing order and shift the results.
The other option is using a for-loop and packing 4-bits at a time, converting that to one hex character, and appending that to your str1.
for(int ii=0, ii<data.size(), ii+=4) begin
bit [3:0] nibble;
nibble = {>>{data[ii+:4]}};
str1 = {str1,$sformatf("data:'h%h\n",data_packed)};
Again, you might have to play with the ordering as I didn’t put too much time into this.
