How do I get a handle to the UVM factory?
I want to use method “find_by_name()” of uvm_factory in my base_test class which is extended from uvm_test.
class base_test extends uvm_test;
   `uvm_component_utils(base_test)
class basic_test1 extends base_test;
    `uvm_component_utils(basic_test1)
      super.build_phase(phase);
     uvm_config_wrapper::set(this,"vsequencer.main_phase","default_sequence", factory.find_by_name("basic_write_seq"));
This code gives the following error :
 Hierarchical name component lookup failed at 'factory'
Then i tried following code :
    uvm_factory factory;
        factory = uvm_factory::get();
This code gives following error : find_by_name is not a class item.
So How can i get handle to uvm_factory??
In reply to rushank27:
From the UVM 1.2 release notes:
The undocumented uvm_pkg::factory variable has been removed, as it was unsafe during static initialization, and incompatible with the uvm_coreservice_t class. References to this variable need to be upgraded to retrieve the factory via uvm_factory::get.
In the second example , as you mentioned , i got the handle by using uvm_factory::get() , but i am still not able to use method find_by_name(). It gives error that " find_by_name is not a class item "
Example :
Sorry, your question did not match your problem. You are getting a handle to the factory correctly. The problem is you are trying to use an early version of the UVM and umm_factory::find_by_name was renamed find_wrapper_by_name.
Use
umm_config_db#(umm_wrapper_object)::set(this,"vsequencer.main_phase","default_sequence", factory.find_wrapper_by_name("basic_write_seq"));
