In reply to Tudor Timi:
Hi Timi,
This is the original method I had implemented. The problem with this is that calls to the drive_control_cycle() and read_control_cycle() tasks each block for 1 cycle and as such `uvm_do_on_with(ctrl_sequencer) will block for 2 cycles.
I need something more like this for my sequence and the entire sequence (execution of the body) should take one cycle as I need to start sending a REQ again on the next cycle…
virtual task body();
for (int i = 0; i < max_seq_length; i++)
// --- Request to CTRL driver - Tell me what I should do.
ctrl_req = ctrl_packet::type_id::create("ctrl_req");
ctrl_rsp = ctrl_packet::type_id::create("ctrl_rsp");
start_item(ctrl_req, -1, ctrl_seqr); // Needed for calculation of RSP
finish_item(ctrl_req);
// --- Calculations based on REQ
starting_agent = $urandom_range(num_agents - 1, 0);
available_credits = BUF_DEPTH - ctrl_req.used_credits;
num_instructions = $urandom_range(available_credits, 0);
if (num_instructions > num_agents) num_instructions = num_agents;
// --- Response to CTRL driver - Do what you're told to.
start_item(ctrl_rsp, -1, ctrl_seqr);
ctrl_rsp.copy(ctrl_req);
assert(ctrl_rsp.randomize());
ctrl_rsp.starting_inst = starting_agent;
ctrl_rsp.number_inst = num_instructions;
finish_item(ctrl_rsp);
// --- Data Sequencer control based off of CTRL request.
for (int i = starting_agent; i < (starting_agent + num_instructions); i++)
int sel = i % num_agents;
data_packet[sel] = data_packet::type_id::create("data_packet");
`uvm_info("VSEQUENCE", $sformatf("***** Starting a DATA packet on agent %0d *****", sel), UVM_HIGH)
fork begin
start_item(data_packet[sel], -1, data_seqr[sel]);
assert(data_packet[sel].randomize());
finish_item(data_packet[sel]);
end join_none
wait fork;
endtask : body
The problem here is that finish_item() blocks until the driver calls item_done() so I think I may also need a way for the ctrl_driver to deal with both REQ and RSP’s at the same time and may need (as you mention) a “driver → sequencer response path”.
I am a little confused by this approach but it seems the only option.
Thanks,
Tom
