How do I bitwise mask Class elements?
I have,
class pq_ctx;
logic [7:0] pkts1; // w6<7:0>
logic [7:0] pkts2; // w6<7:0>
logic [3:0] skip; // w5<63:60>
logic [3:0] max_exp; // w5<59:56>
and I have register mask_pqctx[23:0].
I need each bit of mask_pqctx to mask each bit in class element. How do I do it?
class pq_ctx;
rand logic [7:0] pkts1; // w6<7:0>
rand logic [7:0] pkts2; // w6<7:0>
rand logic [3:0] skip; // w5<63:60>
rand logic [3:0] max_exp; // w5<59:56>
  rand logic [23:0]mask_pqctx ;
  constraint c1 {
    mask_pqctx[23:16] inside {[1:8]};
    mask_pqctx[15:8] inside {[1:8]};
    mask_pqctx[7:4] inside {[1:4]};
    mask_pqctx[3:0] inside {[1:4]};
    (8'd1 << mask_pqctx[23:16]) -8'd1 == pkts1;
  (8'd1 << mask_pqctx[15:8]) -8'd1 == pkts2;
    (4'd1 << mask_pqctx[7:4]) -4'd1 == skip;
  (4'd1 << mask_pqctx[3:0]) -4'd1 == max_exp;};
module top();
  pq_ctx obj;
  initial
     obj=new();
     repeat(100) begin
       obj.randomize();
       $display("mast_pqctx[23:16] = %d,mast_pqctx[15:8]=%d, mast_pqctx[7:4]=%d, mast_pqctx[3:0]=%0d, pkts1=%b, pkts2=%b,skip=%0b,max_exp=%0b",obj.mask_pqctx[23:16],obj.mask_pqctx[15:8], obj.mask_pqctx[7:4], obj.mask_pqctx[3:0],obj.pkts1,obj.pkts2,obj.skip,obj.max_exp);
In reply to mann_verif:
Your question is not very clear. In Digital logic,masks can be used for many different things. They can be used to prevent reading or writing bits, setting or clearing bits. What are you dining with your mask? How do the 24 bits of the mask_pqctx map to the bits in your class? Where is mask_pqctx declared in relation to the class? When is the mask applied?
Here are more details,
I have a class with above properties, I have a mask register which has 24 bits to mask each bit in class. I program this register in cfg sequence, when a modification is needed at bit level for class properties. To get the new class contents original class is bitwise anded with mask with any required programming.
You only answered 1 of my 4 questions. The best I can say is:
{ pkts1,  pkts2, skip, max_exp } = mask_pqctx & { pkts1,  pkts2, skip, max_exp };
Thanks Dave.
