How could i simulate systemc code in questasim using command qverilog
Hi all,
I need following detail to compile
systemC code in questasim using Single Step Command Like(qverilog)
Is there any particular switches for compile & Simulating systemC codes....
Eg: In Cadence they provide some swiches like -sysc under irun…
if any body know tricks to overcome this Issue…
Note: If I add -ccflags “” it only understand *.cpp(C++) file…
Selvavinayakam.na
This exact question was just asked yesterday. https://forum.verificationacademy.com/forum/verification-methodology-discussion-forum/systemverilog-and-other-languages-forum
Thanks Dave for reply,
I referred Questa User Manual, til now i am not getting any idea about that,
If u have any example reference file, please share…
my task is to call system_verilog DPI-C Function from system_C Function…
.sv<----DPI---->.cpp[software_side]<------>*.cpp[system_c Function]…
Selvavinayakam.na
In reply to selvavinayakam.na:
In the /examples/sysyemc directory, there are various examples on how to compile systemc code with sccom.
The SystemVerilog standard only supports a DPI-C to interface with straight C code. You can call an SV function from SC, but only with basic C types. Questa supports a DPI-SC extension. You can see an example in examples/systemc/systemc_dpi.
